Up to 20% off select tools
A 5.5-inch smartphone by Oppo, released in August 2016. Includes a non-removable 3075 mAh battery and a 16-megapixel selfie camera. Model A1601.
Battery Contacts Error , Not charging Problem
How to fix Battery contacts error.
Score 10
5 Comments:
How do I get
by Share
@hadibutt how do you get what?
by Share
Real me oppo c1 not charging
by Share
Bettery conation lose
by Share
Battery stock in 50/not charging battery connection error
by Share
Add a comment
1 Answer
@kamrulhasan we need to see what is going on with your battery contacts. Post some pictures of what you got going on there with your question Adding images to an existing question That way we can see what you see. It could be as simple as replacing the battery to as complicated as replacing the battery connector. Hard to say without seeing it. Use something like this video to replace/work on your battery connector.
Add a comment
Add your answer
Kamrul Hasan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 40
All Time: 1,647
