Up to 20% off select tools
Manufactured by Sony, the ZS-RS60BT is radio-enabled boombox. The device’s top-loading CD-player, USB port, and Bluetooth 2.1 compatibility enables the user to stream or play music from a variety of sources.
FM Radio not working
FM Radio not working, once increases or decreases the volume it starts to produce the speaker sound but not FM is clearly auditable. Some time is works but sometimes not.
Add a comment
1 Answer
Hi @tejas94737
Open the radio and check if the antenna connection from the extendable antenna on the outside of the radio is connecting OK with the motherboard in the radio.
For FM to work you need a good signal
Add a comment
Add your answer
Tejas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 361
