The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
Car is wobbling when driving
My 2000 toyota camry is wobbling when driving. It's really scary because there was noises coming from the front passenger tire area and now this wobbling like the car is off balance, plus my steering wheel is shaking and pulls to the left. What could it be?
Add a comment
Chosen Solution
@linda75783 there are a few possibilities. First check the tires and the rims. Take it to get those balanced if they are still decent. If not, replace your tires. Next would be suspension issues. Bad tie rods, balljoints and bad wheel bearings are all a possibility. Take a look under there and see if you can make out any obvious damage. I’d start with the wheels (tire/rim)
Score 1
Add a comment
You might have a brake problem. A bad rotor, caliper or pad.
Add a comment
Add your answer
Linda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 594
