Repair and disassembly information for the Pixel Fold, Google's first foldable smartphone. Released June 27th, 2023.
Where can I get camera glass replacement
I woke this morning to find a hole perfectly above my camera so that the lens is exposed the camera still works except blurry between 2x-5x so my question has two parts first will the blue go away with a new camera glass and where can I get the glass? Thanks in advance
Score 1
Add a comment
1 Answer
I couldn't find OEM replacement glass but I did find tempered glass lens protectors.
https://www.amazon.com/dp/B0C5R3WFN6?ref...
I then followed the Pixel 7 Pro camera glass replacement. Glue released very easily with rubbing alcohol. I used masking tape to pull any loose shards off throughout the procedure. Used small spurts of canned air to clean everything out once the glass was removed. Turned out pretty good and have no loss of function.
https://www.youtube.com/watch?v=Y1WYIia-...
Add a comment
Add your answer
Steven Keck will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 41
All Time: 1,449
