Apps downloaded are not opening
All apps I've downloaded are operating except two
non of the apps on the phone will open. i have restarted the phone several times and twice powered it down for at least an hour but still nothing. even the apps that are on the phone (calculator etc) will not open. i am not able to receive any calls or messages either
My apps that I downloaded from the play store and install but as soon as I want to open it the phone restart it self
When turning your phone on start in safe mode power button and volume down hold the power button until you see the maker of your device pops up let go of the power button and you will feel the device vibrate and safe mode will be on display, and it will only have the core apps on the phone. If it doesn't restart then you'll have to clear the cache and force close the play store app. It should work by this method. And maybe one of three apps are maybe your issue also check for updates on your device in safe mode to see if you have another install that might do the trick.
In oukitel C33, my apps that I downloaded from the play store and install but as soon as I want to open it the phone restart it self
I have the same problem in oukitel C33.
Oukitel seems not react for the moment, why ???
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 33
All Time: 1,033
I was having the same problem. None of the apps will open. Google stayed in initializing for hours amd probably days, before i even noticed it. After powering it off, multiple times, then it stopped at the name and stays lit up. I can do anything. I want to transfer my things to the desktop, but it doesn't show up. Then I tried to do the transfer with another android tablet, but still having no luck. I don't want to do a factory reset because I have some sentimental things on there that I really need to try to get off. Please help someone!!!!
by latanyaj822
To soft reset an OUKITEL phone, you can try holding down the power button for a few seconds:
Turn off your Android device
Press and hold the power and volume down buttons together
Release the buttons when the Recovery mode screen appears
Use the volume down button to select Recovery Mode
Press the power button to restart your phone in Recovery Mode
Use the volume and power buttons to access the Recovery menu
Use the volume keys to navigate to the wipe data/factory reset option
Select the option using the power button
Entering safe mode
Press and hold the phone's Power button until the power options appear.
Press and hold the Power off button until the Reboot to safe mode prompt appears.
Tap the Reboot to safe mode prompt.
Exiting safe mode
Restarting the device is usually enough to turn off safe mode.
If the phone is stuck in safe mode, checking the phone's buttons individually may help. Removing the phone case might be necessary.
by Harley Middleton
Will wiping the data/factory reset option, delete everything from the tablet? I was hoping I didn't have to do that because i wanted to back up my important data.
by latanyaj822
Nevermind. I just selected wipe/data/factory reset option. This is a fairly new android tablet, so I'm just going to send back for my money. Thanks for the information,
by latanyaj822
Reset would destroy y documents.
It's oukitel responsability to solve this problem
by Franck Menanteau
