An Android smartphone made by vivo.
Why my phone restart automatically
My phone switch off and on itself
Score 9
4 Comments
Blank screen doesn't start
by
@jag72387 not enough information to help you with that. Be more descriptive.
by
Battery problem
by
Restart mobile bar bar
=== Update (05/05/25) ===
by
Add a comment
Most Helpful Answer
If your phone restart automatically and frequently there is battery issue. The battery of Vivo s1 and s1 pro is repairable. Just remove the fuse and jump it with soldering. It wil help 1000%
Score 2
6 Comments:
@rishisaini your answer needs a bit more of an explanation. Why would you remove a fuse (Which fuse?) and apply a jumper to replace the battery?
by
The whole process is explained in this video
https://youtu.be/ImOLtiE0yr8?si=pTfbiYLh...
by
Phone automatically reset
by
All time my phone restart
by
@shaikhshab did you at least try what I suggest in my original answer? Have you changed the battery yet? What have you tried?
by
Show 1 more comment
Add a comment
@nitingarg95976 you didn't tell us what you have checked and what you have tried. A bad battery can cause frequent reboots. Start by replacing your battery. Use something like this video to do that.
Of course this assumes that you did the usual software/firmware solutions, like a hard reset (save all your files because they will get deleted), starting in safe mode, updating your firmware, clearing your cache and making sure there are no rogue apps running it the background.
Score 1
1 Comment:
what could be the reason if the phone is stuck on boot or logo for a long time and needs for both the volume and power button to be pressed simultaneously for a long time.
This is a frequent issue and would like to know a permanent or long term solution.
by
Add a comment
Add your answer
NITIN GARG will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 53
All Time: 3,879
