Up to 20% off select tools
The N6901A is a wireless laser mouse produced by Lenovo. It is symmetric and uses Bluetooth for communication with a computer.
Mouse curser not working
Add a comment
1 Answer
Most Helpful Answer
@imnoobda The basic things to test on a wireless mouse are the battery and examining the battery contacts. First remove the battery, then check the battery springs in the compartment for any rust or corrosion. If there is any corrosion, clean the contacts before replacing the battery with a new one. You can also try pairing the mouse via Bluetooth again.
Beyond that, there isn't much to repair on a mouse and it is often cheaper to replace the mouse altogether if those steps do not work.
Score 1
Add a comment
Add your answer
I'm Noobda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 34
All Time: 624
