An Android smartphone announced by Vivo in June 2016.
My phone automatically on and off
Add a comment
1 Answer
@abdulwahidpatel you are not giving us a lot to work with here. 5 words is just not enough to give you a detailed answer. We can however, provide you with a couple of ideas.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
I suggest that you start with a new battery if any of the above did not work. To check the charging port,use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Since iFixit does not yet have a guide for this phone, use something like this video
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Add a comment
Add your answer
Abdulwahidpatel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 391
