Power bottom not working
Pawer bottom not working
. Open the back door first (pasting by gum)
. Unscrew all
. Open the backcase carefully
. Remove all connected strips
. Remove the mother board
. Remove the power strip.
@kingashis you are not giving us a lot of information. All you could do is give us 4 words to try and help you? It would be nice to know what you have tried to fix this. Or at least to let us know what you have checked.
First off you want to reboot your phone to eliminate any temporary glitches. Press and hold the volume down button and the power button simultaneously for about 10-15 seconds
After that you need to make sure that you have the latest update for your firmware. Check on that by going to Settings > About Device > Software Updates > Check for Updates.
Next clear the cache by going to To clear storage cache, proceed to ******Settings > Storage > Cache Storage
Now if none of that work(ed)s you may have to replace the power button flex. For that use this guide
Replacements are available at plenty of online stores. Just do a search and select a vendor that appeals to you.
Since iFixit does not yet have a guide, it would be great if you could help out. While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Well I will suggest you to check out the following video: https://www.youtube.com/watch?v=1TnPiP_0...
Power button not working
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 73
All Time: 2,996
7 Comments
Change display change
by Syed Rehan Share
@syedrehan44267 why would you change the display if the power button isn't working?
by oldturkey03 Share
Pavar batan Working not
by Bittuu Paswann Share
by Mr. moin1716 Share
Phone power button is demage
by Yash B Share
Show 2 more comments
