A small coffee maker with original Saeco technology, just like the big ones. The model number is HD 8743.
Big bubbles frothing/high pump speed
I have two saeco machines
The Intelia and the XSmall
While the Intelia does a very creamy frothing
The XSmall makes big bubbles (like detergent) and what I see is what after few seconds of pumping the pumping speed increases
Add a comment
1 Answer
This could be an issue with the "crema valve". It's situated in top of the upper piston, see. Saeco Minuto (and compatible machines) brewing unit gasket replacement, step 2. If you open it, you will find a spring and a glass ball, (which might be broken). Replace the ball.
Add a comment
Add your answer
Bruno Masotta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 235
