Up to 20% off select tools
The Sony Xperia XZ3 is an Android smartphone manufactured by Sony. Model number H9493, released in October 2018.
How I enable files application
How i enable files application
Update (08/16/23)
I accidentally disable my "files" application now i cannot find a way to enable it. It shows in settings "apps and preferences".
1 Comment:
@abdulahad27711 you do not provide information about what the problem is. You need to be clear with your question and provide as much detail as possible to get any help with this.
by Share
Add a comment
It seems like you're asking about enabling the "Files" application on a specific device or operating system. However, you haven't mentioned the platform or device you're using. The process can vary depending on whether you're using a Windows PC, macOS, Linux, Android, iOS, or another operating system.
Here are some general steps for enabling the "Files" application on common platforms:
  1. Windows PC: The "File Explorer" is the default file management application on Windows. You can access it by clicking on the folder icon in the taskbar or by pressing the Windows key + E. If you're having trouble accessing it, you might want to check for any issues with your Windows installation.
  2. macOS: The default file management application on macOS is the "Finder." It's accessible from the Dock or by pressing Command + Space to open Spotlight, then typing "Finder" and pressing Enter.
  3. Linux: Linux distributions often have different file managers depending on the desktop environment you're using. Some common file managers include Nautilus (GNOME), Dolphin (KDE), and Thunar (Xfce). You can usually find these applications in your application menu.
  4. Android: On Android devices, the "Files" or "File Manager" app might be pre-installed or available for download from the Google Play Store. You can search for it in your app drawer or on the Play Store.
  5. iOS (iPhone/iPad): iOS devices come with the "Files" app pre-installed. You can find it on your home screen or by swiping down on the home screen and typing "Files" in the search bar.
If you're referring to a specific application named "Files" or a different context, please provide more details about the platform you're using so I can give you more accurate instructions.
Add a comment
I m using android sony xperia xz3. In playstore it shows the other apps not mine one which i accidentally disable
Add a comment
Add your answer
Abdul Ahad will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 31
All Time: 629
