Up to 20% off select tools
The Jeep Patriot is a compact crossover SUV made by Jeep.
Way Abs light is on
How to Turn off abs light
Add a comment
ABS light would indicate a problem in the ABS system.
Fix it and the light will go off.
Add a comment
Have auto parts store check engine codes. You have one for abs. It will give you a place to start such as a defective abs sensor and which one of 4.
Add a comment
Con un diagnóstico te puede aparecer cual es el sensor que esta fallando, me sucedió que uno me fallaba al momento de pasar los 30km, te recomiendo el diagnostico y de ahí te orientes cual tienes que reparar,
Spanish -> English translation:
With a diagnosis you can see which sensor is failing, it happened to me that one failed when I went over 30 km, I recommend the diagnosis and from there you can find out which one you have to repair,
Add a comment
Add your answer
Accent Hyundai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 465
