No boot device available
My computer will not start up. Cannot find boot device. What is most likely cause?
@erichinkle most common issue would be a failed hard drive.
On startup hit the F2 button (may take a couple of times) to enter the BIOS. Once you are in the BIOS check for a boot devices. See if your computer can still find your HDD.
You could also try and set the boot order to USB and get a bootable USB drive. Boot from that and try to access your HDD. I use Puppy Linux Live CD installed on a USB flash drive and use it to gain access.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 422
