Repair and maintenance guide for Bosch 11321EVS, a demolition drill made by Bosch, model number: 11321EVS.
Bosch 11316EVS not power
Bosch 11316EVS gives power at the beginning then shuts down, now it will not turn on can it be the cables ? I already change the fuse i both sides
Add a comment
Most Helpful Answer
Does anything change when you try to wiggle the cable? Try to bend the cable gently in every direction, especially near the drill end.
Score 2
1 Comment:
Yes you are right it was the cable hopefully nothing else comes along the road thank you…
by
Add a comment
No enciende al activar el botón
Add a comment
Add your answer
LUIS PHOTOGRAPHY will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 555
