Repair information for the fall 2018 addition to the ASUS ROG Zephyrus lineup. This is a high-end gaming laptop in the thinnest frame for those specs at the time. Model number: GX531GS-AH76.
Using different edc cable
Hey, so i have zephyrus s gx531gxr. It uses 40 pin edc cable that i have to replace. I have ordered cable from similar model (gx531gx) by mistake, and I am wondering if this cable will work on my device. The main difference is that the gx531gxr has 240hz screen and gx531gx has 144hz.
Add a comment
1 Answer
Most Helpful Answer
@filipklaczek for as long as the pitch of the pins is identical it should work. I did not see any crossover etc, so I would definitely give it a try. After all, if it does not work, you will know that you need to get an original.
Score 1
1 Comment:
Hi @filipklaczek,
If it doesn't work the Asus part number for a GX531GXR EDP cable is 14005-02780800.
Search online using the part number to find suppliers that suit you best.
by
Add a comment
Add your answer
filip klaczek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 226
