Laptop released in 2019 by Acer, Acer Nitro 5 includes 8 GB RAM (expandable up to 32 GB with the proper hardware) and red backlit keyboard.
Compatibility on Acer Nitro 5 Back Cases
I ordered a case for an An515-54 and that was what the website said. However, as you can see, the two look different. Does anyone know if they are possibly compatible?
16 Comments:
Pictures are a bit blurry but they look identical to me. Which part exactly looks different to you?
by
@dannish The patterning on the sides. I can't take my laptop apart myself to see if any of the internals are different, though. They are otherwise identical from what I can see, but I am worried about the possibility of them not being compatible.
by
@samgeorge77840
Aesthetics like patterning are completely irrelevant to it being compatible or not. Unless you can show us the inside and mounting points and measurements, we cannot say from photos.
If you would like to share the source where you bought the part, as well as the identifying information of your laptop, I can do my best to tell you if I know that is a reputable site and your part should be compatible or not.
by
@erelectronics https://www.walmart.com/ip/Acer-Nitro-5-... I got it from here. Looking at what I have in comparison to pictures of a case that looks identical to the one on my laptop, it seems that the inner points look identical to me.
by
@samgeorge77840 Ehh... the walmart marketplace is kinda iffy. It is trying to copy the Amazon marketplace, in which any vendor can list their products and walmart takes a cut, and part of that emulation is that scammers can list scams, as well as inaccurate listings with incorrect product information gets posted with little checks and balances. It is not as bad as Amazon, but it is still full of bad listings.
The best I can say is *if* the part number of "60.Q5AN2.003" is accurate and *if* that is the same part number in your laptop, then it will work fine, and the "patterning on the sides" is completely irrelevant.
by
Show 11 more comments
Add a comment
1 Answer
this is just an comsetic diffrence. they will both work fine.
Add a comment
Add your answer
Sam George will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 368
