Up to 20% off select tools
Introduced in 2017, it was the company's flagship model identified by the code name Sagit. It is equipped with the Snapdragon 835 accompanied by 6 GB of RAM and an Adreno 540 GPU
How to replace screen
Score 4
Add a comment
Most Helpful Answer
@singgsirya iFixit does not yet a guide for this. Use the one from here to replace your screen. Since we do not know where you are located, I suggest an online search for a replacement screen within your part of the world.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 1
Add a comment
Display change
And power bottom change
1 Comment:
I'm going with the assumption you meant "button" rather than "bottom", because the phrase "power bottom" has a whole different meaning in this country than what you probably intended.
If you need to change the electrical part of the button including the click dome, use this guide.
https://www.nadiemellamagallina.com/en/m...
If you want to replace the physical part of the button that you press, use this one.
And see @oldturkey03's answer for the guide to replace the screen.
by Share
Add a comment
Mobile no the wrking
1 Comment:
Mobile display no werke
by Share
Add a comment
Add your answer
Singg Sirya will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 37
All Time: 1,323
