Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
Why is my mac so slow?
Booting up takes 3 Minutes and opening a program like word or mail takes over 1 minute.
7 Comments
Have you considered reinstalling the OS and switching to an SSD for faster read/writing speed?
by
@dinoo_fixit - That’s a strong possibility but not the first thing I would do.
by
@danj Right, but maybe after fixing this issue, replacing the ten years old 7200 rpm HDD with an SSD and increasing the RAM wouldn't be a bad idea
by
@dinoo_fixit - I don’t disagree! The core issue is likely something else.
by
@danj You're right
by
Show 2 more comments
Add a comment
1 Answer
Most Helpful Answer
I would run the onboard diagnostics to see if something is not working correctly. Your system will go into CPU Safe mode which reduces the systems CPU clocking to a crawl!
To get to diags restart your system and press the D key on your keyboard at startup. Here’s a good reference Mac startup key combinations
Let us know what you got for an error/s
Score 2
2 Comments:
Cannot Load EFI/Drivers/TestSupport.efi
This is the error message I get
by
@maximmotyka - That sucks! Thank you Apple! 😖🤬😖🤬
Did you try the online version as well? I hate winging it! Let’s assume the drive is just badly fragmented, then defragging the drive would be what I would do. But before you do that make sure you have a good backup!
I would get this product as I find it’s one of the better ones! Drive Genius it’s what I use.
by
Add a comment
Add your answer
Maxim Motyka will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 35
All Time: 319
