The C875-S7304 is a model of the C Series of laptops manufactured by Toshiba. It includes a 17.3 inch display and an Intel Core i3 processor.
one usb on right side has stopped working
i HAVE TWO USB PORTS ON THE RIGHT SIDE OF MACHINE. ONE PORT STOPPED WORKING AND I CANNOT FIGURE OUT WHAT IS WRONG. CAN ANYONE HELP ME? THE TOUCH PAD WORKS FINE. THE PORT ON THE LEFT UPPER SIDE WORKS. IT HHAS A LOGITECH FAN UNIT CONNECTED AND IT WORKS .
1 Comment
the usb in question will not power any device when it is plugged in to the usb.
by
Add a comment
1 Answer
Most Helpful Answer
Hi @usbnerd
Check if the USB power management setting in Device Manager that allows the computer to turn off power to the USB port is enabled. If so, disable it, restart the laptop and check if it now works OK.
Here's the procedure.
Go to Device Manager - Universal Serial Bus controllers - click on the > symbol to expand the category list - right click USB root hub > Properties > Power Management.
If the allow the computer to turn off this device to save power checkbox has a cross in it, uncheck it and then click on OK. Close Device Manager and any other programs that you have open and restart the laptop in the normal manner and check if the USB port now works OK.
As I don't know which USB Root Hub is connected to which USB port, do this for all USB Root Hub entries listed.
To get to Device Manager in Win10/11, press the Win key + the x key (both keys together) and click on the Device Manager link
Score 1
Add a comment
Add your answer
USBNERD will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 245
