Up to 20% off select tools
The ZTE Grand S Flex is a mid-range smartphone with Android 4.1.
Touch is not sensing
Screen is not sensing
Add a comment
1 Answer
@getachewta93472 if your touch screen has failed, it is time to replace the display assembly. The only guide that is currently available is Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard and not much there. It'll be a start but you will have to move forward gently to see if you can get it done, Of course, use other similar guides too so you can maybe figure it out.
Add a comment
Add your answer
Getachew Taye Gillo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 252
