Repair guides, disassembly, and troubleshooting information for the 9th-generation Apple iPad with Wi-Fi, available with 64 or 256 GB of storage. Released in September 2021. Identified by model number A2602.
Charging port not working
How do I find someone to replace a charging port on an iPad 9th generation?
It was working when it fell off the bed.
Score 3
Add a comment
Most Helpful Answer
First of all, if you're looking for suggestions you'll need to tell us where you're located, as this is a worldwide site and the answer will be very different depending where you are.
Until then, all I can say is you're not in a good position here. Apple did you dirty on the charging port of your iPad; not only is it attached directly to the motherboard so you can't just replace a part, but they also put it on a flex cable, making it even harder to replace. So it's going to take a fairly skilled technician to be able to do the specialized soldering required to fix your port.
You can always do a search for local repair facilities and contact them. Ask whether they have the expertise to repair your port, and what the cost is.
Score 2
Add a comment
it stopped working then i had to fix the charging port.
Score 1
1 Comment:
Same. I Suggest To get an IPAD 9 Lightning Replacement.
by
Add a comment
ipad 9 no charging flex change ic change no charging
Add a comment
Add your answer
Dan Frain will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 40
All Time: 1,814
