An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
Why is my screen so dim?
i remember the sp having a really bright backlight. i feel like mine might be dying. I checked my battery because it was draining so fast, i saw it had swollen up on one side, so i replaced the battery for a new aftermarket. It lasts longer than before, but the screen is still dim and I'm worried the previous battery's condition might have been a side effect rather than the true cause.
battery life on the original battery: about an hour maybe
battery life on the replacement: about 3 hours.
is my screen dying and causing my battery to drain faster?
Add a comment
Usually all video devices that are rechargable have a screen brightness adjustment in the settings you maybe need to check and set it to a brighter setting.
1 Comment:
my gba sp only has a backlight on/off button. thats it, nothing else
by
Add a comment
@charaznabl39130 "screen dying and causing my battery to drain faster?" most likely not. this sounds strictly like a bad back-light. You do want to remove the screen. Clean the connector with some isopropyl alcohol and cotton tip applicator. Check the ribbon cable for tears, corrosion or frayed ends. Check the button with a multimeter in ohm mode, to see if you have continuity when on and no continuity when off.
It also depends on how dark is dark. It is possible that the complete backlight has failed. Let us know the exact model number for your GBA SP and post some good pictures of your board, the ribbon cable and connector. That way we can see what you see. Adding images to an existing question
Add a comment
Add your answer
Char Aznable will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 44
All Time: 2,473
