Repair guides and disassembly information for Microsoft's third-gen Surface Laptop, released in October of 2019.
battery contact cable adhesive
I am rebuilding, having replaced the battery. In one of the later steps you heat the adhesive on the battery contact cable before gently removing. in the reverse - what adhesive should i use to fix the cable? it looks like its fixing to an aluminium patch - should i use thermal compound or regular hot glue or double sided tape?
thanks in advance
2 Comments:
do you mean the flex cable from the battery with the gold contacts ?
by
yes that is it... It looks like it had a copper like adhesive or possibly tape of some kind.
by
Add a comment
1 Answer
Nothing fancy required. just used double sided tape. I did leave the copper P- pad in contact with the chassis. all appears to be working fine.
Big thanks to daniel (above) for help with this
Add a comment
Add your answer
SteveG will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 267
