Model No. A1367 / 8, 16, 32, or 64 GB capacity
unable to boot or restore
i have this ipod touch thats been stuck on the apple logo for an extended period and would seemingly boot loop after ~15 minutes, so i tried to flash ios 6 back onto it and see if that would work. it failed with either error 9 or 1602 every time right after getting to "operation 28 progress -1" in the logs. it always failed because of it apparently disconnecting even though my cable and usb ports are fine. i tried restarting my computer too without any luck. it has a panic log too; device had saved panic logs: panic(cpu 0 caller 0x9c0dbac5): "Failed _ReplaceBadBlock CE 1 PBN 2568" which i unfortunately couldn't find anything on google to help me out. it got a bit warm near the top of the display after trying to recover it, which i didnt notice while doing the same process on a functional one. i noticed after trying to recover it, it would stay on the apple logo and then the itunes one, then loop back to the apple logo. it'd do that for an hour or so and shut back off. im suspecting its a hardware problem but id also like to be sure and know more about that panic log. im really new to stuff like this so sorry if anything was worded badly
3 Comments
would it shut off mid flash?
did the screen fade/ghost?
by
@timtomissus it wasnt shutting off mid flash, but it would stay on the screen with the progress bar for a couple minutes after and go back to looping. sometimes the screen would flash white before looping again but still only after it failed
by
My old iPod touch is stuck on apple logo and just won’t do anything else. I don’t know why. Apple logo and then I can turn it off. I can’t turn it on just stays on apple logo. Totally bummer
by
Add a comment
1 Answer
Chosen Solution
Error 9 for this device is mostly Nand problem. This can be solved with reball the nand, or when have allready critical bad block cout then must be replaced, but the original data (sn, bt and wifi Mac adress) must be copied on the new nand. But error 1602 ist mostly problem with USB timing clock, you can try to connect to some nativ port (not some usb hubs or ports on case) or try to use usb 2.0 port not 3.x. When is the problem with nand and the nand is self ok, can temporary help heat up the device on cca 60°C with hair dryer and flash it when is hot. At least you can see some different or Maybe will flash succes( but probably will work not so long time)
Add a comment
Add your answer
egg will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,258
