The Acer Nitro 5 AN515-43 is a budget-friendly gaming laptop that was released in 2019. Typically features AMD Ryzen mobile processors paired with either NVIDIA GeForce GTX or AMD Radeon RX series graphics.
Charger and power indicator.
My laptop is critical low battery. When I plug in the charger the charging indicator will blink 3× times then power indicator which is blue blink and then they blink at the same time. What is the possible problem and the solution. Thanks for the answer.
Score 1
Add a comment
1 Answer
I have the same issue in the laptop. Mine is because I've used the charging port badly. It will probably need a change of the port.
Also, my fans turn up and down without any reason, and doesn't for a while when a game is being played- get's heated until I turn fans to max in NitroSense.
I don't know if that's related to the charging issue though.
Add a comment
Add your answer
MASHEEET will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 252
