Repair and service information for the LG TrueSteam clothes dryer. Model numbers DLEX3570V, WM3670HRA, and DLEX3570W for graphite, red, and white colors respectively.
Why is my breaker tripping
Why do my breaker keeps tripping especially after replacing thermostat and thermal fuse.
Add a comment
1 Answer
The most common reason for a breaker to trip is excessive current. If the breaker trips instantly when the dryer is turned on then you have a short circuit, probably a short to ground. If the dryer runs a bit before tripping the breaker there is an overload. It helps to have a fundamental understanding of electricity and circuits. If you open the dryer there should be an electrical schematic to follow. I suspect you have incorrectly wired the components you replaced or you used the wrong components. It's difficult to be more specific with the information provided. Also, you may have pinched a wire when closing up the dryer enclosure.
Add a comment
Add your answer
Teedo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 46
All Time: 754
