Up to 20% off select tools
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Apple ID not active
Apple I’d not active what’s the solution to it
Add a comment
Most Helpful Answer
Do you mean that the device is Activation Locked to an Apple ID? Or do you mean there's a problem with the Apple ID and it isn't fully functioning? If the device is Activation Locked, then you'll need to enter the credentials for the Apple ID to unlock it. If you don't know the Apple ID credentials you can attempt to reset them here. If there is a separate problem with the Apple ID, you may need to contact Apple to resolve the issue. You can contact them through the support options on their website. Good luck!
Score 1
Add a comment
It's blocked I can't unlock it
Add a comment
Add your answer
Kehinde Oluwafikunayomi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 295
