Repair guides, disassembly, and troubleshooting information for the 6th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in March 2018. Identified by model number A1893. Features a 9.7" Retina display and 64-bit A10 Fusion chip.
Touchscreen not working after replacing the digitizer
I have got an iPad 6 A1893. It belonged to a family member and while they were using it, the touch screen just stopped working out of nowhere. They did not drop it or anything of the sorts .They were playing a game and it just kicked the bucket.
I assumed that replacing the digitizer was the solution at hand here, but after receiving a replacement component and fitting it, the touch still does not appear to be working, I made contact with iFixit as there is a chance the part is DOA and they will be sending me a replacement component to try.
But i wanted to ask the question here to see if anyone else has had this issue before and what other problem might be the cause of the touch not working.
As far as i can see, all capacitors, diodes etc are intact from the ones in view. But this was just from using a poor magifying glass. I do not have a microscrope or anything like that to check them with.
Any advice that can be given would be great. Let me know if i have missed any information that you would like to know.
Score 2
Add a comment
1 Answer
Most Helpful Answer
this is more than likely a logic board issue, unless you have access to the likes of zxw, or wxj etc then it will be difficult to explain what to look for
Score 1
2 Comments:
I don't know what zxw or wxj means....so I'm probably going to assume no i don't
by
Add a comment
Add your answer
dbhol will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 327
