Repair and disassembly guides for Samsung printers.
Found NOTHING about Samsung Scanner/Copiers! Why?
My Samsung Scanner/Copier model # SCX-4500IXAA needs only light maintenance: It works, but squeeks a bit while scanning. The paper feed roller fails so it thinks it's out of paper. I used to make the paper a bit sticky on top where it's needed. That doesn't work any more. I am able to reach part of the roller deep inside with a long, thin brush, so I tried to apply RubberRenew, but the roller is probably not rubber, but a time-hardened thermoplastic elastomer (TPE) rubbery plastic. So I need help how to open the machine, replace the roller, and lube away the squeek. But I didn't find scanner/copiers as a category. Can someone please teach me how/where to open it completely to let me at least first try to rough up the roller, and suggest a good lubricant for the squeek, if very carefully applied (no spray) WD-40 isn't appropriate.
1 Comment
This question was migrated from https://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Most Helpful Answer
@romen24586 number one reason for the lack of repair guides etc. is the way printers/scanners/copiers/ are built. Plastic housing, sharp sheet metal, lack of repair parts combined with low prices, are making repairs a royal PITA. Anyhow for your issue use Samsung SCX4500 SM. It should at least get you to where you need to be to eliminate the squeak.
While you work on your printer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Score 2
Add a comment
Add your answer
romen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 191
