The Buick Lucerne is a full-size upscale sedan sold by Buick from 2006 to 2011.
blows fuse when trying to crank
When I try and crank the engine the 40 amp fuse for the crank blows immediately
Add a comment
1 Answer
You have a short circuit. Disconnect the solenoid wire for the starter and try cranking again. Of course the engine will not crank but if the fuse does not blow then you need a new solenoid. If the fuse still blows the short is in the wiring. Inspect and repair as required.
Add a comment
Add your answer
Raymond Febles will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 310
