The Anova Precision Cooker with Bluetooth and WiFi is a device designed to use sous vide (pronounced “sue-veed”) to cook food to precise temperatures.
No Power when Plugged into outlet.
Bought a 2019 anova precision cooker bt wifi. Used only twice. Used yesterday. Went to use it again today and I get nothing powering up when plugged in. No visible switch or fuse. Tried three direct wall outlets but still zero power. Is this fixable I am sure as hell not dumping another $180 to replace it!!!
What would be the most likey cause for no power? Is this fixable?
Add a comment
1 Answer
Most Helpful Answer
Hi @richardmulawa
There's a fuse shown in Step 4. of the ifixit Anova Precision Cooker BT WiFi Teardown guide.
Select the small image, 3rd to the right at Step.4 to see its location.
If it is blown, then as to why this occurred would have to be further investigated. Fuses do not usually fail for no reason
Score 1
Add a comment
Add your answer
Richard Mulawa will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 23
All Time: 1,517
