Small business desktop computer introduced by Dell in 2007.
How to fix 5 beep sound
my pc makes 5 beep sounds before it starts.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @willaalex
A Vostro 5 beep error code means that the RTC (Real Time Clock) coin cell battery on the motherboard has failed.
This battery is used to maintain the BIOS settings when the PC is turned off.
Here's the owner manual for the PC. Go to p.150 to view the procedure to remove/replace the battery.
I think that the battery is a CR2032 Lithium coin cell battery which is available most everywhere e.g. supermarkets. Check the battery type number which should be stamped on the battery to confirm.
Once you replace the battery you may have to adjust the date and time on the PC after it is first started. This is because the BIOS has been reset back to factory default settings due to the battery being removed i.e. no battery power. Once you have adjusted the D&T the message won't appear the next time the PC is started.
Score 1
Add a comment
Add your answer
Willa Alex will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 1,784
