Up to 20% off select tools
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
Disc will stop spinning
My discs will initially start and load up, I can play for a few minutes. Then the disc will stop spinning during game play. I’ve tried cleaning the lens to no avail. Curious if this sounds like a fixable issue? Has happened with multiple games.
Score 1
Add a comment
Rather than typing them all out again, this thread has a number of potential solutions to the issue you are having, hope this helps!
Disc not spinning in GameCube
Add a comment
This is a very common problem with all disc drives, the disc motor bearings get a tiny bit tight and it doesn't rotate at sufficient speed to recognise the disc, trying adding a tiny, very tiny! bit of oil to the disc motor bearing and see if it works
Add a comment
Add your answer
M Doe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 725
