Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
Why is my dsi doesnt charging?
i tried to charged my dsi at first but the charging light doesnt turning on. but my dsi xl is showing it was charging, i thought it was just some error. but then after 2 hour, i noticed that the battery percentage is still at 50%, so i tried changing another place to charge but still not increasing. what do i do? should i change the ac adapter or change the battery or something?
Add a comment
1 Answer
For posterity,
TL;DR - Component U11 is faulty.
I have a console with that exact problem. After fixing the female battery connector that was ripped off the motherboard board, I noticed both the positive and negative were shorted, which was very odd since it wasn't my solder job. Cross-checking with board schematics, I noticed that pins 9 & 10 on component U11 were shorting to GND on pin 4. Pin 9 & 10 were connected to the positive pad of the battery connector, so they shouldn't be shorting to ground like that. Replacing U11 from a donor board fixed the issue.
1 Comment:
To add: If that didn't worked, you can try to test with a new battery. But most likely it's just the U11 causing this.
by
Add a comment
Add your answer
raihan kavindra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 287
