Repair guides and support for motorcycles manufactured by Harley-Davidson.
My speedometer light works intermittently
On my 2009 stock dyna streetbob the backing light for the speedometer goes out at cruising rpm. When I let off the throttle and go back to idle rpm the light comes back on. This happens consistently. All other lights, the speedometer, odometer and clock are all working correctly.
Score 1
Add a comment
Chosen Solution
I believe it turned out to be the stator
Add a comment
Have seen a couple different things cause this issue;
1. Bad voltage regulator
2. Wires under rear fender getting worn away by the tire and creating a short
3. Loose battery terminal connection
4. Speedometer might be going out
I'd start with the easy stuff like checking the wires tightening the battery connections/making sure the terminals aren't super corroded and go from there.
Hope this helps!
1 Comment:
Thank you Robert H. I'll start there👍
by
Add a comment
Have exactly the same issue. Did you fix it?
1 Comment:
I believe it turned out to be the stator. I replaced it
by
Add a comment
Add your answer
Jesse Duncalfe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 622
