The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
T. 5.5 Torx striped
I ordered your large fixit kit with all the torx and such but when following exact directions in removing the 5.5 Torx screws from this droid 2 (Global) they started to strip the 5 is way to small to start I went to a 6 torx and was able to remove three.. Any hints to remove these other stripped screws? I am about to just drill them out.
Score -1
Add a comment
1 Answer
Chosen Solution
Check out the answer here for some suggestions on stripped screw removal. If you go the route of power tools just be sure to be careful and steady so you don't damage any surrounding components. Good luck and I hope this helps.
Add a comment
Add your answer
John McGrath will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 1,150
