A wireless, more traditional video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
Left stick double clicks and gets stuck
My pro controller (2017) has a problem with its left stick that seems to double click when pressed down to the right. The right stick doesn’t do this. After opening it up, I noticed that the left stick has a loose part in the module that the right one doesn’t.
Score 1
Add a comment
Most Helpful Answer
Thank you for this, I realised I had the same issue, glue didn’t hold so I use a small thin elastic band and wrapped it around the area to hold the loose part in place and now it no longer sticks:)
Score 1
Add a comment
Eventually it's gonna fall off, but luckily it hasn't yet so gluing it into back into place should be easier. Use a small amount of a strong glue to put it back in position, if you don't want to replace the whole joystick. You can use your working joystick as a reference for where exactly it should be.
Add a comment
Add your answer
Juexis will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 33
All Time: 1,082
