Refresh of the original BlackBerry Bold. Known in some circles as the BlackBerry Bold 2.
Water Repair Bold 9700
How I Can Repair A Water Damage?
Score 1
1 Comment
most likely you will need a new battery, once you have cleaned the phone I'd buy a new battery and then see what if anything works, get back to us.
by
Add a comment
Chosen Solution
Guillermo Eirin, I would start by disassembling the phone and cleaning it. Use this as a general guide. You can find a teardown for your phone right here. There is also a take apart guide on here. . Hope this helps, good luck.
Score 2
Add a comment
Shake and wipe water off , open phone and wipe parts (try with a non static cloth ) put phone in a bowl of rice for a couple of minutes(30) that will take out extra water if next day it does not come on get a new battery and see if problem continue if it does get a new phone .
Add a comment
Add your answer
Guillermo Eirin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 2,419
