Up to 20% off select tools
90A Welder with a 30 to 125A Hot Welding Range.
Strikes a arc before I pull trigger
Add a comment
If your talking about a wire fed welder, it is supposed to do that if the stinger touches the metal before you pull the trigger.
Add a comment
There is not a relay built into the system design to start, or power on, the wire circuit when the trigger is pressed. So the design is more like an Arc welder where the stinger, in this case the wire, circuit is always powered on.
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 486
