Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
Deck will not lower when fully powered on
Hi! My husband and I recently got a craftsman zts7500, when the mower is on the deck will not raise or lower and shuts off. But if it is on aux power the deck will raise and lower. We have adjusted the clutch after installing a new one, we have made sure the belt it routed correctly, and battery is fully charged. Also we did a continuity test on the PTO switch and that was fine. And we replaced the filter, cleaned carb and the filter new. And did tested for spark on the spark plug and it was fine. But still can’t figure out why the deck will not raise or lower when the mower is on and it shuts off as soon as we try to.
Add a comment
1 Answer
Some lawn mowers have a travel setting in the key switch and the you turn the key switch to the mow setting to actual mower with it. I've never herd of a lawn mower with a aux setting on the key switch.
Add a comment
Add your answer
EGugino will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 354
