The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
White top screen and damaged shell hinge
I replaced my top screen, but its still broken?
Add a comment
1 Answer
Fixing a hinge almost always means a reshell. As for the screen, if you know the new one works i'd suspect a bad connector. Inspect all the pins for any that look bent or out of place, and gently try to wiggle the outside ones to check that the solder joints are solid. If you find any that aren't, they'll need to be re-flowed
Add a comment
Add your answer
Supersharkgem will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 151
