Uses a smaller heatsink and a user-screwable stand.
Front USB and USB-C ports not working
I took apart my PS5 to deep clean it, wasn't the first time I've done this. But when I put everything back together, I tested the USB and USB-C ports, and they were not working. The backports were fully functional. Any help?
Score 1
Add a comment
Most Helpful Answer
You may have connected something wrong, missed a connection, or messed up the port
Score 2
Add a comment
The flex ribbon connector that connects the usb A/C board to the main board is very fragile. Inspect the cables gold pins to see if they are damaged, also inspect the gold pins inside the connector as they can also get mangled.
Add a comment
Add your answer
Odiin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 1,562
