2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Computer unexpectedly shutting down after battery replacement
I recently replaced my battery with an ifixit battery. I calibrated the battery per the instructions, but the computer is unexpectedly shutting down while I still have significant battery life remaining (i.e. 62%). It will restart immediately and will sometimes run for a decent amount of time and sometimes shut down again immediately. It seems to run fine while plugged into the power adapter.
Score 1
1 Comment:
same problem but after 3 years and only 174 cycles. Pram reset, SMC reset, baterry disconnected and reconnected still shows "service is recommended" and performance on battery is short and erratic.
by
Add a comment
1 Answer
  1. Check battery health: Use a tool such as CoconutBattery (Mac) or BatteryInfoView (Windows) to check the health of your battery. If the health is low, it may be time to replace the battery again.
  2. Reset SMC: Try resetting the System Management Controller (SMC) on your computer. The steps to do this vary depending on the model of your computer. You can find instructions on Apple's website.
Add a comment
Add your answer
Michael Weinberg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 238
