Up to 20% off select tools
A mid-range smartphone from Samsung released in 2019 with an improved camera over the A50 model.
How to change charging socket
Score 3
Add a comment
Most Helpful Answer
This guide should come in handy: https://www.youtube.com/watch?v=8cnKvU91...
Make sure you order the daughter board that corresponds with your model, otherwise you may have service issues.
Score 1
Add a comment
If i charge my fone it is not charging and i show to someone he replace it's motherboard and after few day it happen again
Add a comment
Tombol volume tidak berfungsi
Add a comment
For changing a charging socket, start by switching off the power supply at the circuit breaker. Remove the socket cover by unscrewing it and then disconnect the wires with caution. Install the new socket by linking the wires to the correct terminals and then fasten it securely. Turn the power back on and check if it is functioning properly.
Add a comment
Add your answer
Ashpreet Singh will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 15
All Time: 634
