Up to 20% off select tools
A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
How to remove joystick caps
I have ordered new joysticks for my lite, but wanted to know if it was possible to remove the original joystick caps?
I have a pokemon edition lite with the non standard joystick colors and they are still in mint condition (minus drift). So was hoping to move them to the new joysticks.
Update (03/26/23)
No amount of pressure let the cap come off.
Seeing as the drift had already killed the joystick I decided to tear it down.
It appears that Nintendo has the stick and cap molded as a single unit in production, so its not possible to get the cap off to swap onto the new Guli sticks.
At best I might be able to get just the rubber cover off, but no idea if that would fit the Guli caps.
I am happy to have my sticks working again, but also sad that I am losing the unique coloring.
Score 1
1 Comment:
You can't easily, it is actually glued on.
by Share
Add a comment
1 Answer
You should be able to just pull them off once you have the joysticks out, but I've never even held a switch lite, so you might want to verify that
Add a comment
Add your answer
Daniel Peregrym will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 71
All Time: 2,512
