Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
What all parts is needed?
I see a few different parts listed for the 42mm series 3. my screen is falling off basically but i know it does still work. what all should be bought to do the screen replacement?
1 Comment
screen is shattered. I forgot to put that up there.
by
Add a comment
1 Answer
Most Helpful Answer
Hi Zach,
In theory, if your screen has indeed come loose, then the only thing you should need is the adhesive to glue it back on.
Apple Watch (42 mm Series 3) Adhesive Strip
However, it's been my experience that the screens generally don't just fall off for no reason. Most commonly it's because the battery has swollen and pushed the screen off the face of the watch. If that happens, then you need to add a replacement battery to your list of parts. I can't tell you exactly which one to get, as it appears there are differences between the cellular and GPS models of the series 3.
Anyway, you'll want to take a look at the battery itself; if it's at all pillowy or puffed up, that's a sure sign it needs to be replaced. A good, functional battery should have the outer layer wrapped tightly around it like a brick.
Replace the adhesive strip compatible with the 42 mm case Series 3 Apple Watch model A1859, A1861, A1891, and A1892. Image
Product
Apple Watch (42 mm Series 3) Screen Adhesive
$6.99
Score 2
3 Comments:
I forgot to mention that the screen is shattered but the watch still works.
by
@forsaken1 Ah, well that does change things. You can just buy the screen by itself, but then you'll need that adhesive I mentioned earlier as well. A better choice would be to purchase the Fix Kit which not only has all the tools needed, but includes the force touch gasket as well. The gasket frequently gets damaged when removing the screen so it's a good idea to have it on hand just in case, but it also serves as the adhesive to hold the screen on.
You'll still need to determine which one you need, the GPS or cellular version, as apparently the screens are different.
Apple Watch (42 mm Series 3 Cellular) Screen
Apple Watch (42 mm Series 3 GPS) Screen
by
@dadibrokeit awesome thank you
by
Add a comment
Add your answer
Zach will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 18
All Time: 353
