Up to 20% off select tools
Repair information for the Dell Latitude 6000 laptop series.
How to fix dark screen?
My laptop turn on and to see what is on my screen, I have to use a flashlight, without the flashlight i can almost see nothing. The brightness is turned all the way up. This is happening a while now especially when I turn down the brightness of the screen. Can it be fixed without pulling up the laptop? help me.
Score 2
Add a comment
1 Answer
@tanaythomas this "I have to use a flashlight" means it is your backlight that is not working. That could be a issue with the physical backlight on your LCD panel. It could also be that this is related to the backlight circuitry on your motherboard or the cable/connector from your motherboard to your LCD. Right now I would like to say that this "Can it be fixed without pulling up the laptop" would be a No. You will most likely have to disassemble your laptop and even take some measurements with a multimeter.
Add a comment
Add your answer
Tanay Thomas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 242
