Is there a fuse there?
Where is located the fuse and how can I approach it?
Try the following methods to restore power to the Brother machine:
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 1,145
There are numerous fuses. Can you describe the symptoms?
by Jim Share
The printer does not show any sign of life after an unclear power interruption.
by tvarozna Share
