How do I reset the BIOS password?
Removing/replacing the CMOS battery doesn't work, and there's no "code" it gives you.
To answer the question if it can be cracked easily anymore: NO. Hasn't been viable since Haswell introduced Boot Guard killed the infamous workaround we employed since the 390E. Any machine with the 40 designation (e.g. T440, Haswell P series) or newer is a no-go; same rule on the consumer machines (Haswell and up=uncrackable). The motherboard has to be swapped unless you can somehow dump the BIOS, decrypt it and remove the BIOS password without marring the code such that it changes the private key (which gets verified by Boot Guard) and blocks the bootup process at the BIOS signature check level. This is in addition to hoping against hope the TPM/security trip doesn't throw the 0192 tamper error (this is nearly unfixable; some old models may be workable but forget about it on the Boot Guard generation due to Intel). They secured these things down, cryptographically and physically.
Lenovo never had a backdoor password but has practiced security theater for nearly a decade. If you can find the ATMEL chip and short SCL and SDA together quickly, it bypasses the password so you can remove it. The catch was to remove it for good; you had to go into the BIOS immediately to wipe all of them out for it to persist. Lenovo stores it in the NVRAM on the new ones, not a dedicated chip. This contrasts with the old laptops that stored them in the ATMEL chip; this is why anyone with the knowledge can get the job done in minutes. The only way to remove it on the newer Lenovos is a clean dump of the BIOS and a "blank" TPM/ATMEL chip dump that you have to directly flash to the board with a chip programmer. Lenovo has required this for a long time, even on the consumer side as well, but Haswell and Boot Guard made it significantly more difficult (in contrast, for years on end, removing the battery was enough on consumer-grade laptops).
On the business models (ThinkPad) with older models like the XX30, the solution was to find the ATMEL chip and short 2 lines, or use an HW tool to do it (sold by an Australian); even this no longer works on the newer Think laptops (XX40-present) with the POP being in the protected NVRAM as well now. It's a motherboard replacement for both the consumer and business system unless you can get Lenovo to reflash the BIOS and EC firmware (or get a clean dump, do it yourself, and program the information to the motherboard yourself). This also needs an NVRAM wipe if the password and BIOS are stored in separate spaces. Lenovo denies this can be done and makes you buy a motherboard when it can be done by wiping and reflashing the EC firmware/NVRAM and BIOS EEPROM to ensure the job is done. You will have to reenter the machine's S/N, UUID, and machine type to finish the job, though. Reflashing both areas is the only way to be SURE the password is gone.
Regardless of the type, the newer laptops (Haswell-present) either use Intel Boot Guard or VERY ROBUST signature checks, which means any attack on the NVRAM or BIOS code if you dump it to attempt to reset it and remove the password or attacks on the ATMEL chip corrupts it and kills the boot process until the "correct" BIOS image is in place which will make the password issue come back :(. These new Lenovos (IdeaPad and ThinkPad) are not built around the idea of security theater like the old ones. Anyone who knows how to locate the ATMEL chip or properly dump and hack the BIOS can fix it. We laughed at these old Lenovo laptops and got the job done; now we don't bother and bin them with the ThinkPad that smoked since they have just as much value.
HP has had real security in place since the process can only be done on the right machines (read: older and exploited, takes a few years to be added to the list of ones which can be cracked) by dumping the BIOS (often requiring a chip desoldering operation due to physical security; some old laptops can be done without it if it has the exposed side pins on the flash ROM), the unlocking tool (easily found online, NOT NAMING NAMES!), and reflashing the original "unlocked" BIOS to the main EEPROM (which gets shadow copied to the backup on SureStart laptops to ensure it matches up without the password). Main swapping is impossible as you CANNOT MIX THE MAIN AND BACKUP BIOS on those laptops unless you have both ROMs from a clean board (at which point.... swap the board unless it has LD but a "clean BIOS"). Dell is the only vendor that practices BIOS security theater (please keep practicing it. It helps the used market and doesn't turn them into parts machines).
I'm interpreting the third paragraph as, TL;DR: Late 2022+ ThinkPads, IdeaPads and Thinkbooks can't reasonably be reset... Cheapest to replace the motherboard. Correct?
@jeffreyhawkins Haswell+, so 2012+. Boot Guard was a Haswell feature and made it impossible to bypass.
Can I still bypass a T14s Gen 3 thinkpad?
Take a toddle over to :: Lenovo Flex 4-1130 Laptop BIOS Update
and follow the instructions ????
That's updating the BIOS, not resetting the password.
Have you tried removing the BIOS battery? When I say battery, I mean the little one on the mother board not the one that powers the whole system.
@jim10203 Yes, nothing.
Any update on this?
For X270 is it possible to reset the bios password? How to upgrade with a new ssd if I can't access the bios after 0199 error: system security password retry count exceeded. Thank you
Haswell+, no. Intel Boot Gard+private key prevents the reset as it alters the key when you dump and remove it.
Did any one managed to wipe and reflash the EC firmware/NVRAM and BIOS EEPROM?
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 67
All Time: 15,662
