Up to 20% off select tools
Model No. A1367 / 8, 16, 32, or 64 GB capacity
Dfu mode need help please
I bought the ipod at a yard sale and when I try to rest it it says it has previously been in dfu mode and it has to be put there again how
Update (03/16/23)
this is the message I get
Add a comment
download 3u tools then download the restore firmware and use it...that should solve the problem
1 Comment:
had ur problem sovled
by Share
Add a comment
well, you need to put it in dfu mode again
you need to power down the ipod
then hold down the home button and power button after you hit the power button
it should say connect to itunes
then connect to itunes
and it should work
https://www.youtube.com/watch?v=zAPCvA6a...
heres a video guide if you need more guidance
and comment if you need any help :)
2 Comments:
This does not work. When attempting to do this all that happens is the ipod restarts and the message will come up again
by Share
I've seen that on my ancient iPod Touch. For some reason, the Finder on recent releases of macOS can't restore an old iPod Touch from DFU mode.
But I was successful doing it using iTunes on a Windows PC. If you don't have a Windows PC, see if you can use a VM or emulator to run Windows and iTunes from there.
by Share
Add a comment
Add your answer
Joshua Cameron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 774
